Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 09-26-2011, 02:36 PM
byrde byrde is offline
Disengaging AWD
Looking for 2002 or newer Jeep Grand Cherokee what models will let you disengage All wheel drive?
Old 09-30-2011, 03:31 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Disengaging AWD
It depends on which system is installed on the Jeep. If it's a Full Time 4wd (aka AWD) system then 4wd cannot be disengaged except by removing the front driveshaft. However if there's a part time TC then you should be able to shift into 2wd.
For 2004 and earlier models you could tell by the shifter on the TC but after that I'm not sure if you can do the same thing.
Do you have a Jeep or are you considering getting one?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Bravada AWD problem SOLVED macbunch Problem Diagnosis 0 11-02-2010 10:15 AM
1998 Bravada Service AWD Light easton82 Problem Diagnosis 2 06-10-2010 04:35 PM
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 04:04 AM
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 10:59 PM
94 Astro AWD - front brakes? stan_5150 M Bodies 2 04-06-2010 07:47 PM
