Old 09-26-2011, 08:59 AM
pp270 pp270 is offline
Power Steering Pump Mowns
I have a power steering pump that makes a mowning noise when turning. Normally this means your fluid is low, but mine is full. Is it possible the reservoir is clogged not allowing fluid into the pump? When you take the cover off the reservoir the fluid is frothy so you know the pump is cavitating.
Any other ideas of the issue?
Old 09-26-2011, 10:07 AM
Tech II Tech II is offline
Re: Power Steering Pump Mowns
If that fluid is frothy, you have a leak somewhere, because you have air in the system....
Old 09-26-2011, 10:23 AM
Agreed, but if there was a leak in the system wouldn't the level in the reservoir decrease? It maintains the same level.
Old 09-26-2011, 12:04 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
You for sure have a leak, look for seepage around lines, pump shaft seal and steering gear stub shaft seal. Just because its not leaking enough for you to see a level drop, does not mean it cannot pull air into the system from the leaking area.
Old 01-15-2012, 12:11 PM
stratovani stratovani is offline
I also have this problem with my power steering, but it only makes that moaning noise when it's cold outside. Once it warms up to a decent temperature, say 35 or above, it stops. Today it's really cold outside, around 15 degrees, so it's moaning loudly and the fluid is frothy. Yet in the summer you'd never know you have a problem. Any ideas?
Power steering pump removal Oddball16 Taurus | Taurus Wagon 1 07-11-2011 06:48 PM
How To R&R 1998 Grand Caravan Power Steering Pump CarBob Caravan | Voyager 0 04-04-2010 10:59 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
92 deville 4.9 Power Steering Pulley sheered / fell off and destroyed belt! 92Deville Deville 1 06-03-2009 06:51 PM
