Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-26-2011, 12:45 AM
dh271 dh271 is offline
Send a message via AIM to dh271
Dash lights turning off at night
Something messed up concerning my dash lights. When it`s nighttime my dash lights go off. They work fine in daytime, doesn`t matter whether I turn on headlights, running lights or pull the relay or turn dimmer switch any direction. I covered the sensor in day light to make it think it was night and they turned off, uncovered it and the dash lights came back on in a few seconds. Any ideas or should I just buy a Yugo....
Old 09-26-2011, 11:45 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Dash lights turning off at night
The headlight switch contains circuitry that controls the automatic operation of turning the DRL's ( day time running lights ) off and activating the regular headlights when it gets dark outside . It also controls the dimming of all interior lighting ( dash cluster , etc. ) when the regular headlights are on . Your switch is bad and needs replacing - I say this from my actual experience with the same problem . My dash cluster , floor mounted gearshift indicator lights , door mounted power window and lock lighting , and all miscellaneous interior lighting would go completely out when the regular headlights were activated at night . I replaced my switch and the problem was fixed ! Hope this helps .Good luck !
" Sometimes I grow so tired "
Old 09-26-2011, 03:21 PM
Thanks for the input, I`ll scope the out the switch.
Old 09-26-2011, 04:31 PM
Are you talking about the headlight/dimmer switch on the left side of the dash close to the driver door?
Old 09-26-2011, 09:32 PM
oldblu65's Avatar
Yes , the switch on the left side of the dash that allows you to manually turn the headlights on as well as adjust the brightness of the dash lighting .
Old 09-26-2011, 11:06 PM
I was a little confused when I typed in headlight switch on youtube and watched them change out the multifunction switch on the column. I thought it might be the instrument panel dimmer switch. Thanks!
One other question, do you know if the sensor on top of the dash could be disabled by itself and I wonder if it would have any effect of keeping the dash lights on since it wouldn`t be reading between light and dark anymore?
Old 09-27-2011, 05:04 AM
oldblu65's Avatar
I don't know enough about the dash mounted sensor and the intricacies of the wiring to even try to advise you about disabling it ? I am going to send you a PM giving you another option on this and other potential problems with your car .
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
98 Olds electrical - interior lights turn off 63johnm Silhouette 0 07-12-2010 12:32 PM
How do I rewire my 1995 Magna so the lights turn off when the car turns off? Captain_Glen General Discussion 1 07-11-2010 06:55 PM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 07:35 AM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
