Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-24-2011, 09:28 AM
scorpiowoman1025 scorpiowoman1025 is offline
Unhappy Engine stalling, cutting out, surging
I posted an earlier problem about my 1995 Olds Cutlass Supreme with a 3.1 liter V6 engine. The car has about 185000 miles on it. I realized it needed some maintenance done so we did a fuel cleaner, oil change and replaced the pcv valve and plugs and wires. It ran great for about a day or so and now it is stumbling on the freeway and also stalling out completely at stop signs, almost like it isn't getting fuel or something. I have also replace the fuel system including fuel pump, twice, fuel filters twice and fuel pressure regulator. All in the last couple of months. I also during the last few days have done the oxygen sensor, map sensor and again checked the plugs and wires. We also put in a new air filter. It seems to be getting much worse and I am not sure what is completely causing it. It is not giving us anything in the way of codes and a recent trip to the shop was not able to solve the problem. My mechanics are kind of stumped and so is the repair shop, any ideas about what to do next?? I can't afford to continually having to worry whether I will make it to work or home
Old 09-25-2011, 06:42 AM
Tech II Tech II is offline
Re: Engine stalling, cutting out, surging
Can you easily recreate the problem? If yes, then time for a new mechanic....
Old 09-25-2011, 08:48 AM
Obviously if I could one of the two shops and mechanics would have been able to figure it out. It doesn't always do it or on a regular basis and there are no codes. However we did replace the plug wires because one had a defect in it and the throttle position sensor and the battery. It is quite a bit better but still a little surging, no more stalling though and it starts right up.
Old 09-26-2011, 11:51 AM
Cammy_01 Cammy_01 is offline
My friend just stalled out coming up my driveway.. from the surging at speeds and at idle and stalling my first step was to check fuel pressure. Key on only, 30 PSI exactly when fuel pump hums for a second, then when I release the fuel pressure with the gauge, key still on, it drops to zero, but some fuel still trickles out the release on the gauge continuously with no hum from the fuel pump, but amazingly it still sometimes runs. Maybe someone can chime in, but my question is a bad fuel pump or does the computer control voltage to the fuel pump. Everytime the key is turned on it hums and goes to 30 psi, but did not 2 times out of 20 times we tested it.. also turning key on and at 30 psi then key off it does hold pressure so I assume holding pressure means the fuel pressure regulator is good.
My suggestion to the originator of this post is have that fuel pressure checked or buy a $35 dollar fuel pressure gauge at Autozone and check it yourself.
My friends car is also a 95 3.1 v6 and your symptoms sound very simular and possibly the same issue.
The Following User Says Thank You to Cammy_01 For This Useful Post:
scorpiowoman1025 (09-26-2011)
Old 09-26-2011, 12:03 PM
I appreciate that, it was one of the first things we checked but fuel pressure and pump are working fine. I am leaning more towards the egr valve now. We have also replaced the tps sensor, battery and wires again, one was fried and it made a huge difference in the last couple of days. It is running almost 90% better, still a small hesitation now and then but doesn't stall and gas mileage is better!! Good luck hope you get yours fixed soon
2001 3.8 stalling/cutting out on highway expotrek Impala | Impala SS 3 06-03-2010 07:44 PM
95 Stalls, cuts out. Roadfish Prism 1 11-12-2009 04:36 PM
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 07:23 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
