Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-23-2011, 07:59 PM
capetoker capetoker is offline
Unhappy program a keyless remote
Hi I have a 2002 impala 3.8 litre and am trying to program my new remote I tried turning the key on and the radio off pushed the button menu comes up and prog fob comes up push the next button the push fob comes up but will not flash can anyone tell me why it will not flash or how to make it flash? Thanks Glen
Old 09-23-2011, 10:40 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: program a keyless remote
I was not aware you program a key fob without a scanner on this car. I do know that with the scanner, when you are in the program mode, you must push "lock" and "unlock" buttons at this same time for the remote control door lock reciever to recognize it.
Old 09-24-2011, 06:36 AM
Unhappy Re: program a keyless remote
Hi thanks for the reply .I checked out how to program a remote for a 2002 chev impala on the net and this is what I found in a bunch of treads.
1 Enter your vehicle with your ignition key in hand and close all of the doors behind you.
2 Insert your key into the ignition and turn the key to the "On" position. Switch off the radio.
3 Press and hold the "DISP" button on the radio until the "Settings" menu appears on the radio display.
4 Press the down or up arrows until the display reads "FOB PROG," and press the "Next" button.
5 Press the "DISP" button again and wait for the display to read "PUSH FOB."
6 Press and hold the lock and unlock buttons on your keyless remote until the car responds with a chime. This may take up to 15 seconds.
7 Repeat step six to program any additional remotes.
8 Press the "DISP" button again to exit the programming mode and you will be free to use your newly programmed remotes
Everything works as described except the prog fob will not flash maybe it will have to go to the dealer .What do you think ?Thanks again
Old 09-24-2011, 07:57 AM
gmtech79's Avatar
gmtech79 gmtech79 is offline
I have always had to use a tech 2 to program fobs. The service manual says nothing about programming through the radio.
Sent from my Droid X. Typos probable.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 09-24-2011, 08:49 AM
gmtech1's Avatar
is it a new key fob? Are you sure it's the correct one for the car?
Old 09-24-2011, 03:26 PM
Hi it is a new fob I got it from ebay and it sayes it is for a 2002 impala and malibu but I am not sure if it is the right one. But the problem is that the push fob will not flash to let me try to program it.Mabey this is not the way to do it was just trying what it sayes on the net .Thanks
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 05:06 PM
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
