Old 09-22-2011, 08:08 AM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
95 Windstar dies when put in drive
My Dad has a 95 windstar with 3.8 motor. Recently it dies every time it is put in drive. It feels something like if you were driving a standard and let off of the clutch too fast without accelerating.
If you start out in 1st or 2nd and then move the gears manually it works fine. O/D light blinks occasionally. I had him try to get codes pulled and the only ones that showed up were 0171, 0174, and 1407. I don't think these codes would cause his issue.
Any help is much appreciated.
Old 09-24-2011, 06:05 PM
wiswind wiswind is offline
Re: 95 Windstar dies when put in drive
I would have it checked out by a trusted mechanic.
It sounds like a issue with the transmission, the torque converter is supposed to permit slip in the system....and it sounds like you are not getting any/enough slip in the system when it goes into gear.
The other thing that can cause stalling is a sticking Idle Air Control (IAC) valve on the top of the throttle body.
However, I would expect it at other times as well.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
'96 Windstar stalling when put in reverse or drive nomi123 Windstar 3 04-30-2007 06:35 PM
94 grand am se 3.1 dies when put into drive schneppsta Grand AM 0 03-25-2007 10:25 PM
94 Villager dies when put into drive spencers Villager 5 07-17-2005 02:46 PM
93, Loss of RPMs, stalling, dies when put in drive. ideate.net Regal 3 11-29-2004 08:23 PM
engine dies when put in drive. burnsie629 Rodeo | Passport | MU 1 08-31-2003 07:46 PM
