Old 09-21-2011, 10:10 PM
pcabn pcabn is offline
2001 Park Avenue
I have a 2001 Park Avenue 152,000 miles. Runs great handles great. But I do have a clunking sound coming from the rear of the car. I think it is something with the rear axle. It has new shocks last year. I can't find anything obvious and it doesn't seem to effect the ride or handling. I'm just trying to figure out the noise.
Old 09-22-2011, 07:31 AM
maxwedge maxwedge is offline
A990 racer
Re: 2001 Park Avenue
No way to pin this down from here, you need to duplicate the noise maybe by bouncing the car while you are under there feeling around. Too many things can do this.
Old 09-22-2011, 10:39 AM
Tech II Tech II is offline
If you can create the clunk, at a low speed, over bumps, maybe you can ride in the trunk, and determine if its on one side or the other, in a parking lot somewhere.....
Try moving the exhaust(when cold)....move it side to side and see if it hits something like a loose heat shield....also tap the cat to see if anything is loose inside....
Have you looked under the vehicle to see if anything is loose, like a heat shield, hanger, shock bolts are tight, etc.?
Old 09-25-2011, 07:08 AM
I can't find anything loose that is what is puzzling. It happens going over certain bumps, rough blacktop...... Doesn't make the car handle bad but I would still like to know what it is. If the road is smooth you would never know you are riding in a car with 152,000 miles on it. I will look at it again today to see if I can find something.
Old 09-26-2011, 07:00 AM
Blue Bowtie's Avatar
Registered Offender
You can remove the carpet folds and trim caps from the trunk, get in with a good lamp, and have an assistant jounce the car slightly. Look for motion between the upper strut stem and mount, and the upper mount and the body.
Try to avoid getting locked in the trunk.
Old 09-29-2011, 08:44 PM
xs03mich xs03mich is offline
Look at the rear body mounting bolts to the frame. The rust will start under the washer and the bolt will move/rattle when you go over bumps etc. It doesn't take much, just try to tap on the mounting bolts.
You can give the car the old shock test, but the bolt will not make a noise!
Drop the bolt that is loose, put a bigger washer on and you will be good to go.
Old 09-30-2011, 07:22 AM
squekyj squekyj is offline
ive had this problem before look at the rear suspension and see if u have a rear sway bar if so the rubber links where the bar attaches to the control arms are prob bad .. they wont look bad u just kinda got to really inspect them to see ..
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
2001 Park Avenue IAC screw mcmlxv Park Avenue 4 04-15-2007 06:35 PM
2001 Park Avenue Front Seats mcmlxv Park Avenue 2 04-05-2007 11:54 AM
New Member: 2001 Park Avenue mcmlxv1 Park Avenue 2 11-28-2006 02:04 PM
2001 Park Avenue ride TopherS Park Avenue 4 02-03-2006 11:33 AM
