Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 09-21-2011, 02:08 PM
greybeard851 greybeard851 is offline
Do I need a switch for DRLs?
I have an 89 Tempo and I am trying to install a pair of 55w off-road lights to become DRLs since the car doesn't have any. I am going to run the current from the battery through two relays before going to the lights. The first relay will only energize after the car is started. The second one will drop out when the headlights are turned on.
My question is... Since the current is effectively shut off by relay one until started, do I really need an on/off switch in line also? If I absolutely must then I will have to run the wires through the firewall and that would be difficult to do without a shoehorn... if you catch my drift.
BTW, needless to say, there will be a 15a circuit breaker in the line between the battery and relay one.
Thanks for the help,
Greybeard
drl and lcm questions sveiks2u Aurora 1 06-28-2010 09:05 PM
i need a combo auto switch? for my blinker noise JessicaJane Suburban 3 03-12-2005 09:02 AM
I need a fog lamp switch for a '99 V6! Thanks. edunovoa24 Mustang Talk 1 04-22-2004 01:16 AM
Need Overdrive switch for automatic 84 Isuzu Impulse esmith Impulse 1 11-10-2003 08:39 PM
Need switch for my 90 integra's sunroof 90_IntegraLS Integra 2 09-30-2003 07:40 PM
Tags
drl , install , switch
