Old 09-20-2011, 08:31 PM
kevink1955 kevink1955 is offline
96 waterpump tube to lower hose
My 96 with a 3.8 engine just started leaking from the steel tube than connects the waterpump inlet to the lower hose, the tube has rusted out. I know that the small tubes on the top that connect to the heater hoses have had problems but this is the first time I have heard of the lower tube going bad.
Anyone done one, what are the chances I can get the tube out of the pump. I know it is a push in with an O ring to seal it but I wonder if it's going to be a problem geting it out.
Old 09-24-2011, 06:13 PM
wiswind wiswind is offline
Re: 96 waterpump tube to lower hose
Sorry that you have not gotten any replies.
I have no experience with this part, and I guess you won't know until you get into the job and try to remove the tube.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-24-2011, 08:16 PM
Thanks Wiswind
I posted earyer today but it got lost somehow
I did the job this morning, the tube came out of the pump with a little wiggleing.
It was not rusted out as I expected, the cause of the leak was the paint or powder coat finish on the tube had delaminated and since the O ring seals on the outside of the tube (on the finish) there was a path for the coolant to flow under the finish. What I thought was rust was a blister in the finish that the coolant was escaping from.
I could have cleaned the tube up and reinstalled it with a new O ring but since I already had the parts I installed the new one.
Now I just have to wait for the rain to stop so I can look for leaks when I park in the driveway.
The tubes & hose joints question shineofleo Car Modeling 6 03-17-2011 11:40 AM
Tubes to rear heater core corroded, Options?? '00 GV cheepnis Caravan | Voyager 1 07-15-2010 11:52 AM
2005 galant evaporator housing drain tube location mwoods Galant 1 06-28-2010 09:52 PM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
lower hose for edelbrock waterpump 502 slong1958 Chevelle 1 12-06-2008 02:30 PM
