Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 09-20-2011, 01:21 PM
ryanusrey2012 ryanusrey2012 is offline
98 Cadillac Deville Concours
hi i have a 98 Cadillac Deville Concours and the low beams do not work yet all the fuses are intact is this a ground problem or a security feature i am still figuring this car out and the highbeams still work but when i turn them off the runners are the only one to work and also one headlight is broken but the one that is not defective does not work
Old 09-20-2011, 01:33 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: 98 Cadillac Deville Concours
I don't think it will be a ground problem as the Hi-Beams share the same ground wire. It could be that for some reason the wire(s) going to the low beams has no power going to it. Check the plug socket to see if it has power going to it. If it does then replace the bulbs. If there is no power You will have to probe the wire for the lights with a test light to find the bad section.
Old 09-20-2011, 03:09 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
There is a high/low beam relay in the underhood fuse box you can check also.
Old 10-19-2011, 10:28 AM
my relays look fine and so do the fuses. could the daytime running light module be causing this because they do not come on only the parking lamps do. also i heard on newer vehicles if a bulb goes out the computer will stop sending power to the defective lights untill the computer is resetted any ideas?
Old 10-26-2011, 01:13 PM
could it be the dimmer switch? thats what the dealer told me but they always want you to buy all their parts to and they just said dimmer switch with no logic behind it
Old 10-26-2011, 02:27 PM
maxwedge maxwedge is offline
A990 racer
A shop manual with a circuit tracing diagram is the only way to properly diagnose this or there will be a lots guess work in the repair process. BTW, relays can't look okay they must be tested or substitued
1957 Cadillac DeVille Sedan for sale carsonrestoration Cars/Parts for Sale/Exchange 0 03-23-2011 08:45 AM
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 09:04 PM
1994 cadillac deville concours shakes at between 55 to 60 mph pepsiPAID Deville 2 06-23-2009 08:55 AM
1998 cADILLAC dEVILLE cONCOURS,LOCATION OF IAT SENSOR, and TPS Sensor jspeigne Deville 4 06-02-2008 03:14 PM
1995 Cadillac Deville Concours Perfect Condition Below KBB Northstar V8 Deville 0 11-22-2003 02:53 AM
Tags
beams , ground , headlights , low
