Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-20-2011, 06:56 AM
rdgirod rdgirod is offline
97 Saturn SC1
My 97 Saturn SC1 dies as I slow to stop. It will restart but the RPM goes very high for a little while before it drops back down to normal. What do I need to do to fix it?
Old 09-20-2011, 11:04 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 97 Saturn SC1
The first thing is to scan for any trouble codes ! This is generally done for free at most auto parts stores ( i.e.- Autozone , Advance Auto , etc. ) . It could be a variety of things causing this and the scan should narrow that down to a specific area . You don't want to just start replacing expensive parts until you're somewhat sure what the problem is ! Good luck and keep us updated !
" Sometimes I grow so tired "
Old 09-21-2011, 08:52 PM
Cat Fuzz Cat Fuzz is offline
Re: 97 Saturn SC1
Remove the throttle body and clean it. Also, remove the IAC valve, clean it and the passage. If that doesn't fix it, replace the IAC valve.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 09-27-2011, 08:55 PM
good2us good2us is offline
Re: 97 Saturn SC1
Does your car have automatic transmission? My '97 SC1 with the manual experienced a similar issue. The engine speed would flare whenever I depressed the clutch pedal and take a while to go back to normal, but the engine would never die (the clutch is disengaged as I approach a stop). I had a P1404 (EGR Valve Closed Position Performance) code, but nothing else, and the engine was still strong. The puzzling part was the engine never idle roughly. The problem seemed to show up suddenly, but it took a year for me to really notice it. It took another six months for me to solve the problem. What was wrong? I knocked a vacuum hose from the intake manifold off the evaporative canister purge solenoid when I changed the crankshaft position sensor for a crank-no start issue. I'm not sure if this will help, but I hope it does.
1994 Saturn SC1 Headliner Bubba5930 SC/SL/SW 0 06-09-2005 02:56 PM
Saturn Sc1 Or SC2 Good First Car?... RicerKid15 Car Buying Q&A 1 06-07-2005 09:34 PM
95 Saturn SC1 for sale IwantWS6 Cars/Parts for Sale/Exchange 0 06-02-2004 05:05 PM
saturn sc1 greenlinks15 SC/SL/SW 1 04-03-2004 04:17 AM
2001 saturn sc1 zanfardino SC/SL/SW 1 07-02-2003 01:43 PM
