Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-19-2011, 03:55 PM
AdVenture AdVenture is offline
Need help locating a Relay
When I put my A/C on I can hear something come on but it isn't the blower motor cause that's dead. I bought the new Motor but the mechanic says I also need to change the relay. I did check the "Search" option but to no avail. I know it'll be behind the dash somewhere but before I strip my car down to the wheels looking for it maybe someone can give me the exact location and save me some time.
Thanks
Old 09-20-2011, 12:28 PM
scottnhalifax scottnhalifax is offline
Re: Need help locating a Relay
cant see it being the relay. most times it is the Main Blower Motor Resistor located under the dash behind the blower motor. you can get a cheap one for 20 or so.
http://www.autopartstomorrow.com/par...cdelco-product
2000 safari awd
Old 09-20-2011, 03:01 PM
Just called the mechanic back he clarified it for me that it was the resistor not the relay thanks I know where that's at. I bought a blower for $65 at autozone and now you're telling me the resistor's only $20. The job is easy as hell 20 mins top and he wanted $355 for the job!Meinekie,cough, cough!
Old 09-20-2011, 06:47 PM
So I go to Autozone and pick up the resistor for $31 (With shipping the site you showed would have come up to $27.75). So I guess I just paid a $4 convinence fee by picking it up locally. Anyway my buddy told me to replace the resisitor then check the original blower. Guess what? there was nothing wrong with the original blower. So I went back inside and returned not only the relay but the blower too. So what the mechanic quoted me as $355 turned out to be a $31 5 min job.
Old 09-21-2011, 12:18 PM
rkvons's Avatar
rkvons rkvons is offline
Welcome to the world of "Take it in or do it yourself". Congrats!
Old 09-23-2011, 10:57 PM
463's Avatar
463 463 is offline
you may have a blower moter on the way out. the moter may be drawing just over the rated amps and in turn blowing the resister. i have seen a lot of this in the last two years. but you mite get lucky.
Old 09-24-2011, 08:51 AM
Tech II Tech II is offline
Could also be a water leak problem, hitting that hot resistor block.....but the new ones are redesigned to resist this...any water on the passenger side floor?
Old 09-24-2011, 02:54 PM
I sure hope I am, for now the blower is blowing strong.
Yes, I do have moisture on my passenger side floor but it's hard to tell what its from. Its Jetski season so the kids tend to bring water in the car. It's also Raining alot and I keep getting caught with my window down. I guess now that I decided to keep my windows closed all the time hopefully it'll dry up. If it is coming from inside i'll find out soon enough.
Since I've changed the resistor the heat pumps pretty good as it's always done but I'm not getting the A/C that I used to. I'm also getting a weird whistling coming from under the hood. I'm hoping it's not the water pump.
Old 09-24-2011, 07:40 PM
vary rare for a blower motor to go on these.
2000 safari awd
1990 Cherokee,need help identifying relays dnvreldrdg Cherokee 0 05-30-2005 07:15 PM
Need Help Locating OEM Corner Lens for 85 Camry sickhonda Camry/Camry Hybrid/Vista 1 09-13-2002 02:34 PM
I need help locating kits/parts for my 99 camry!! aznguy119 Camry/Camry Hybrid/Vista 6 08-08-2002 06:04 AM
