Old 09-19-2011, 12:15 PM
usermyong usermyong is offline
Intermittent No Start - ignition circuit?
Thanks in advance to anyone who has any input. I have a 1996 Jeep Cherokee (sport, six cylinder, 4WD) that won't start occasionally. 98% of the time, it starts up without problem. When it doesn't work the scenario is: put the key in, dash lights up, begin to turn the ignition switch, and suddenly the whole system looses power - no lights on he dash and of course, no cranking of the engine. If I try again immediately, I either get nothing or maybe power until I start to turn the key. If I wait ~5 minutes and try again, it fires right up. This has happened in various weather conditions.
Another problem that might be related is that about 40% of the time, it cranks but won't start in PARK. If I switch to NEUTRAL and try again, it fires right up.
Again, thanks for any thoughts you might have!!
Old 09-20-2011, 07:45 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Intermittent No Start - ignition circuit?
Sounds like the NSS, Neutral Safety Switch. Numerous threads on here that mention it and give instructions for the fix.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-20-2011, 10:35 AM
Scrapper Scrapper is offline
AF Premium User
i agree with neutral safety switch as fred said.
Old 02-04-2012, 12:48 AM
Follow up:
Took a while to sort out. There were two problems at play. The NSS did need cleaning, but the other problem was that my battery cables were very corroded. I didn't notice this because the terminal looked fine - it was the copper wire that was trash. All well now; thanks for the help!
Old 02-04-2012, 10:40 AM
Glad you found the corroded battery cable; that can cause several issues, hard starting among them.
Back on the road and trail!
Old 02-04-2012, 12:03 PM
AF Premium User
Follow up:
you'll never forget that one just because cables look good don't mean wires inside are clean and good.anyway glad you figured it out and back on the road again best part it'll start anytime now.
good luck.........
Intermittent hard-starting, no codes johnnyzero Lumina 14 09-22-2011 07:21 PM
2000 F150 - Possible Ignition Problem? Intermittent Start Failures farns F Series 10 02-16-2011 01:39 PM
89 F150, Hard Start Ignition or Fuel? JAGSARGE F Series 10 11-16-2010 11:41 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 05:03 PM
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 01:37 PM
