Old 09-19-2011, 06:42 AM
MarPac MarPac is offline
3.0 96 Windstar front "clunc"
Hi all,
my Windstar is a bit "clunky" at the front axle. When I stop and turn the wheels right, than a clunk noise appears from both front struts or somewhere there. Whe I turn left, the same. But if I woul'd like to try it when stopped, nothing. Only if I have just stopped or after axceleration.
I bought new struts, wheel bearings, upper strut bearings hoping to fix this. The arms, steering joints, stabiliyers are OK, mostly changed few months ago.
Any other hints? Thanks a lot to Europe :-)
Old 09-26-2011, 10:01 AM
suburbanstevie's Avatar
suburbanstevie suburbanstevie is offline
Re: 3.0 96 Windstar front "clunc"
I know you say the connecting rods are all OK. But I needed to have mine changed several years ago to fix a similar problem. I seem to remember them being "verticle" but can't recall what they attached too. But they were about 10 inches long, and had the spherical bearings on both ends. I found them to be bad because the rubber boots were deteriorated, and the grease was gone.
Good luck,
Steve
1990 Chevy Suburban, 454 cu-In, R2500
(always parked in the garage)
1999 Oldsmobile Intrigue, 3.5L
1998 Windstar, 3.0L
1984 Toyota Pick-Up, 22R
Old 09-26-2011, 05:46 PM
tempfixit tempfixit is offline
Good luck,
Steve
Steve are you refering to the sway bar links???? Yes if worn they will clunck when hitting bumps.
Old 09-26-2011, 06:22 PM
Yes, I believe that is what they were.
1998 Windstar, 3.0L
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 01:11 AM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 09:19 PM
96 3.0 windstar burning rich on 87 octane Rotorman Windstar 1 03-24-2007 05:50 PM
