Ranger auto trans interchange
Hello all,
I find that once again I'm in the need of help from the forum. The problem is with a '99 Ranger 3.0 automatic 4x4. Both the original 4x4 transmission and transfer case were removed and replaced with a 2wd auto trans. I guess the truck worked until the reverse band broke,which was a couple of years after the swap was made. Not so sure about this since I bought the truck in its present broken state. Anyway, I'm wanting to replace the trans and transfer case and return the truck to its original 4x4 condition,and I really need help finding what transmissions will be a direct fit. Are the Explorer automatics and transfer cases the same as those used in the Rangers? If so,what years will fit? Thanks for any help. |
Re: Ranger auto trans interchange
The problem is the engine,,,options are limited by 3.0 engine ...check ,,,car-part.com,,,you will see what I mean.....
| The Following User Says Thank You to trannyman52 For This Useful Post: | ||
Guest user (09-18-2011)
