Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 09-15-2011, 07:20 PM
headfirst headfirst is offline
Installing a tach in my 2002, E150, 5.4L
I am new at this forum. Please excuse me if this same post appeared earlier. I am not sure where it went if it did make it in.
I am trying to install a tach in my van but I am not able to find clear information on how I can do it. I have COP ignition, which adds complexity compared to ignition systems of the old days.
Where can I acquire the tach signal? I read that I might be able to pull it from my PCM (possibly pin #48) but it will be only 5v instead of the 12v I need. I also heard that I might need a tach adapter. I searched adapter manufacturer's instructions but they leave me even more confused.
Finally, I saw but did not capture a simple DYI test adapter made with a LED light that I can probe wiring to help locate the pulsing tach signal. I would like to make one of these so I can keep from screwing up.
Any help or advice will greatly appreciated.
Old 09-15-2011, 10:51 PM
Re: Installing a tach in my 2002, E150, 5.4L
I thought of another option, getting a instrument cluster from a '03 and up. I still would likely have the issue of obtaining the tach signal and possibly other instrument signals compatibility between my '02 and a later model. Of course there would be the a different odometer reading. Can the odometer assembly be swapped?
FAST IDLE with New IAC - 2001 E150 5.4 leroge Econoline 0 01-19-2011 04:46 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
2003 F150 Supercrew V8 5.4L rough idle making popping sounds pat53 F Series 5 11-12-2009 06:30 PM
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
Service Engine Light 99 Ford E150 5.4L Triton dodidupa Econoline 0 03-16-2005 06:33 AM
Tags
adapter , cop , tach
