01 deville
I have a 01 deville the front valve cover gasket is leaking oil. Is it hard to change gasket.
Re: 01 deville
There is a fair amount of dissasembly involved, including needing the correct puller to remove the water pump drive pully, also the camshaft seal behind the pully will need to be replaced. Sometimes that pully can be a real bear to pull off.
I recomend looking at a manual and reviewing the process to see if it is something you will feel comfortable with. Good luck! |
