Go Back   Automotive Forums Car Chat > Saab > 9-3
Old 09-11-2011, 07:35 PM
danolsn danolsn is offline
Saab 9-3 Smoke on Cold Start--Injector?
Hello
I have a 2001 saab 93 and when I start the thing in the morning there is a cloud of grey smoke for a few seconds. After a few seconds the cloud is gone and the exhaust is not visible. Oil and coolant levels are stable. Engine runs and accelerates beautifully. Warm starts do not cause the cloud. Does this sound like I might have some fuel accumulating in a cylinder? Like a leaking or dirty injector? If it sounds like an injector, what should I do to resolve this. Is it a serious problem?
I've read online that when the turbo dies it often makes the car smoke. Hoping a Saab expert can give some input on what might be happening here.
Please not the turbo...
2001 Saab 93 2.0Turbo Auto Transmission
This is very similar to what I am having: http://www.youtube.com/watch?v=Hr45QYjOwcM
Old 09-11-2011, 08:47 PM
old_master's Avatar
Advisor/Moderator
Re: Saab 9-3 Smoke on Cold Start--Injector?
Without a doubt it's oil. It doesn't take much to make a cloud of smoke, maybe a drop or two, and you'd never notice it on the dip stick as being low on oil. Could be one or more valve stem seals leaking or an oil seal in the turbo. Most likely a valve stem seal though. A turbo oil seal would most likely smoke on acceleration. Pull the spark plugs one at a time and inspect them for a dark brown or black deposit on the porcelain insulator next to the center electrode. That will confirm which cylinder(s) is/are causing the problem.
Another test for valve seals is drive at a steady 60 or so mph for a minute or two. Then downshift one gear and decellerate, (foot off the throttle) to around 20mph, then accelerate and have someone behind you watch your tail pipe for a puff of smoke.
You have to know how it works,
to figure out why it doesn't.
Old 09-11-2011, 09:07 PM
If this is a valve stem seal is the only resolution replacement? Also, is this something that is a major issue?
Old 09-11-2011, 09:12 PM
old_master's Avatar
Advisor/Moderator
The only resolution is replacement. Not difficult, just time consuming. Provided you keep the oil level full, it won't hurt the engine. It will however contaminate the catalytic converter and oxygen sensors over time.
Old 09-12-2011, 09:41 PM
Thank you!
I've been reading online and it sounds like the PCV Parts were recalled on this era Saab. would this be a cause of my issue?
Also, I noticed that if the car is started cold and not warmed all the way before shutting off, it creates a larger cloud on the next start than it normally would. It normally goes away after <5 seconds.
Old 09-13-2011, 03:05 PM
old_master's Avatar
Advisor/Moderator
Probably not PCV causing the cloud. PCV deals with oil vapor, the cloud is caused by liquid oil entering the combustion chamber.
A cold startup, without bringing it up to operating temp, can easily add to the cloud by allowing more oil into the overhead area where the valve seals are. Something that can also contribute to the problem is clogged oil returns in the cylinder head. If oil is allowed to accumulate around the seals, it's very easy for it to leak past the seals, down the valve stem, and drip directly into the combustion chamber.
Did you try the decelleration test?
Saab Gains Breathing Room with $222 million Investment From Hawtai Motors AF News Desk General Discussion 0 05-04-2011 06:06 PM
2006 Saab 9-5 codes 1301 and 300 nero11 9-5 0 08-06-2009 08:45 PM
2001 Saab 9-5 service soon and code 730 nero11 9-5 0 08-06-2009 08:43 PM
Saab 9-3 Convertible Aero Ignite 9-3 0 07-09-2003 12:45 PM
New Saab 9-3 vs New Acura TSX max2 Car Comparisons 8 02-06-2003 01:46 PM
