Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-11-2011, 01:08 PM
dhop11 dhop11 is offline
malibu issue
if my theft light is on steadily pass lock is in malfunction mode so if my battery gets disconnected and reconnected will this cause the car not to ever start??
Old 09-12-2011, 01:03 PM
Tech II Tech II is offline
Re: malibu issue
I would say yes......if the light was activated AFTER the vehicle started, it's kind of like a fail safe mode.....the light stays on, and the vehicle will continue to start......
However, if you disconnect the battery, you are back to square one......now if you try to start the vehicle, and the problem is still there BEFORE it is cranked, then the car won't start....
Old 09-12-2011, 01:35 PM
Re: malibu issue
I switched the lock cylinder back to the original after installing another one trying to trouble shooting the theft system.
I realized that when i went back to the old cylinder when i restarted the car i was using a hardware store key, could this be the reason it did not learn the key code??
with the light on 3 days no problem so far, also before never had a light on, just shutting down and hard starting for the past 2 years..
Old 09-12-2011, 09:08 PM
Re: malibu issue
This is a PassLock system...it uses a plain key.....It is the PassKey (I, II, or III)system that uses a resistor or transmitter( in the key head)....
Brake issues on a Chevelle Malibu 1976 gagnon1s Chevelle 15 07-20-2011 12:27 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 07:49 PM
05 Malibu factory radio - adding MP3 xokayxo Malibu 1 09-22-2009 03:03 PM
2005 Malibu Maxx owners manual jkerr41 Malibu 3 07-03-2009 06:46 AM
03 Malibu Brake Issue frame1520 Malibu 1 03-01-2009 09:25 AM
