Go Back   Automotive Forums Car Chat > Suzuki > Aerio/Liana
Old 09-11-2011, 07:25 AM
MTrachy MTrachy is offline
Wheel Bearing
Looking for some advice on how to remove the front hub (need to replace the wheel bearing) on a 2002 Aerio. Thanks
Old 09-13-2011, 09:42 PM
Re: Wheel Bearing
Okay, so it was fairly straight forward....
1. Remove Wheel
2. Remove the 2 bolts holding the caliper on and tie the caliper up out of the way.
3. Remove the 2 bolts holding the brake pad holder on
4. Remove the center bolt (30mm socket)
5. Remove all the suspension pieces attached to the hub being careful not to damage any of the rubber parts
6. Remove the ABS sensor bolt and sensor
7. You should be able to tap the hub off now
8. Have the old bearing pressed out and a new one pressed in
9. The installation is the reverse
Old 12-13-2011, 01:00 PM
Nate Jacoby Nate Jacoby is offline
Re: Wheel Bearing
I just finished replacing the wheel bearings on my car. I had never done it before but it was fairly easy. I looked for awhile online for a great set of instructions and these were the best I could find. I hope they help and there were a few tools that I needed to borrow from a friend of mine.
http://connect.timken.com/removing-a...aring-assembly
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
