Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 09-09-2011, 09:55 AM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
LT1 Engine break-in procedure
Been a long time since I posted here since i sold my bird. My friend still has his 95 Formula, and about 6 or 7 months ago, at 170,000 miles, the engine developed a crack in the cylinder wall and hydrolocked.
A new crate motor is being installed as I type, and he is pretty much clueless about break-in. He is also clueless about using the internet, so I figured i'd come on and ask for him how to break in an engine correctly.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 01-29-2012, 11:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: LT1 Engine break-in procedure
This engine has a hydraulic roller camshaft in it, so there is no special cam break-in procedure to be followed. you may start it up and idle it right away to check for leaks and make any running adjustments.
To bed the rings in properly, what I like to do with a new engine is take it out on the road somewhere there's not a lot of traffic, and run it hard to about 45 MPH or so (not from a standing start though, make sure you're about 20MPH or so before you punch it), then back off and let it engine brake to about 20MPH, and repeat. Do this for about 10 times. Keep in mind that during the bedding in phase, oil consumption will be higher than normal and you may see blue smoke in the exhaust. This is nothing to be concerned about; it is completely normal. Keep an eye on your oil level.
Other than that, be gentle with it (no lugging, towing, high RPM or anything else) for at least the first 500 miles. Change your oil and filter at about 500 miles, then again at 1,500 miles, then again at 3,000 miles, and then normal change intervals hence forth.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
engine break-in thunderbirdcoupe89 Thunderbird 2 12-10-2009 01:22 AM
Proper procedure for new engine break-in jsnowbordr47 Suburban 6 05-24-2009 09:50 PM
New engine break-in procedure AxisPower M3 1 07-23-2004 06:59 PM
Engine Break-In v_knot Engine 11 10-25-2001 06:25 AM
