Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 09-08-2011, 06:03 PM
broughy84's Avatar
broughy84 broughy84 is offline
05 Uplander, thump on rear driver side
05 Uplander 2wd, standard suspension, 115k miles.
I have a loud thumping under the driverside rear. It sounds as though something is hitting the underside of the van when you run over a bump on the rear driver wheel. I've changed the shock to no avail. Any suggestions?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-08-2011, 06:10 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 05 Uplander, thump on rear driver side
These vehicles have a problem with the rear axle bushings causing noises, they may appear ok, but the rubber gets weak resulting in knock/thump type noise over bumps. They are the foreward most bushings where the axle bolts to the body.
Old 09-08-2011, 08:42 PM
broughy84's Avatar
Ya know, come to think of it, there was an oily residue on that bushing when I first noticed the noise. Is that bushing something that I can change in my driveway or will I need a press to get it out and back in?
Matthew Brough
Old 09-08-2011, 09:22 PM
broughy84's Avatar
Oh, and this does NOT have Independent Suspension. Everywhere I look online for that bushing defaults to parts for vans with IS. I don't have that.
Matthew Brough
Old 09-08-2011, 11:23 PM
gmtech1's Avatar
Yeah, the bushing I'm talking about is for the straight axle (yours). It could be done in the driveway. If you have a ball joint press and can mix and match some adapters to install the bushing. That part of the axle is'nt very ridged, so it moves around alot it you try using a hammer. Just pay attention to how far through to push the bushing.
Old 09-09-2011, 12:52 PM
broughy84's Avatar
Errrr.... dealer only part.
Matthew Brough
Chevy Uplander - Upgrade Rear (and front) Wiper Blades spike88 Uplander 2 06-04-2010 11:52 AM
thumping in driver side wheel marquis00 Explorer | Explorer Sport Trac 19 05-20-2007 11:28 AM
Car rear driver side lower than other side... castroltran Wheels/Tires/Suspension 4 07-16-2005 12:57 AM
Rear Driver Side Quarter Panel GsxAon Off-Topic 1 12-30-2003 01:24 AM
Wanted: Sunroof glass, rear driver side glass, ans safety neutral switch hvshaisam ES300/ES330/Windom 2 11-30-2003 06:10 AM
