Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 09-08-2011, 09:51 AM
kawtool kawtool is offline
1998 Trans Sport
How do you remove the center console panel to replace the blower speed control switch? Or do you have to?
Old 09-08-2011, 12:44 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 1998 Trans Sport
Are you talking about the one below the radio? If so, there are two screws down low. I think you may have to open the ash tray or something. There is one on each side at the bottom. Once these are removed, you simply pull straight out at the bottom, working your way to the top. The tricky part is that the top is sorta hinged into the dash a little. When you are putting it back together, you first need to sorta tuck the top part in and then tilt it down and pop it in place. Then put the two screws back in. So keep this in mind while trying to remove it. You can't just pull the top out, it is under the dash a little. Once this piece of trim is removed, there are two screws holding the heater control in.
Power locks - 1998 Trans Sport iso2kengineer Trans Sport 0 02-02-2009 04:57 PM
1998 Trans Sport air bag error code PZ0R Trans Sport 2 10-03-2008 04:29 PM
1998 trans sport wrong temp displayed LEW--C Trans Sport 2 10-12-2006 06:10 PM
1998 trans sport no interior lights LEW--C Trans Sport 1 10-11-2006 06:59 PM
1998 trans sport wont start after sitting a long time LEW--C Trans Sport 2 09-05-2006 09:56 PM
