Go Back   Automotive Forums Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 09-05-2011, 08:11 PM
tannerr52's Avatar
tannerr52 tannerr52 is offline
Repaint!
Ok, so this is my first post EVER on ANY forum, so please bear with me. My car has the nasty, faded, bad silver paint from the early 90s. How could I go about repainting this? Do I abslotuely need to prime? Or could I just sand and paint over the old paint? Im going to use trusty ol spray Rustoleum, because its a cheap car and im cheap .
Thanks.
Tanner
1990 Pontiac Bonneville- 200k -3.8L SOLD Bye Bonnie I'll miss you.
1998 Jeep Grand Cherokee Laredo- 5.2L V8 - 140k TOTALED You were an ok Jeep...
Current ride:
1996 Jeep Grand Cherokee Laredo- 4.0L L6 - 110k
Old 09-05-2011, 08:38 PM
LearnAutoBody's Avatar
LearnAutoBody LearnAutoBody is offline
Auto Body Mod
Re: Repaint!
If it is just fading, you can sand it down and paint on top of the paint. If the clear is peeling, you will need to strip all of the clear off. However, you should not need to prime unless you sand to metal. Then, only prime the metal spots. Don't know much about that king of paint. Are you talking about spray can? There is a cheaper method that may work better. Here is a site that explains the process...Duplicolor
DIY Auto Body Tutorials
"Coming together is a beginning; keeping together is progress; working together is success."
`Henry Ford
Old 09-05-2011, 09:00 PM
tannerr52's Avatar
Re: Repaint!
Yeah Duplicolor and Rustoleum sound kind of the same. Rustoleum has all kinds of paints, some that are made specifically for auto use. Its designed to stop rust... It works quite well but is pricy...
Also!
How do i go about clearcoating it? Do i sand the new paint so the clear can adhere?
Current ride:
Old 09-06-2011, 06:15 AM
Auto Body Mod
Re: Repaint!
You probably need to read the directions for the brand that you use. Most lines of paint, you can spray our clear coat about 30 minutes to 1 hour after spraying base coat. No sanding between base coat and clear coat.
`Henry Ford
