Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-04-2011, 09:05 PM
Ducaire Ducaire is offline
Just got Camry stuck in ditch, now fuel level gauge is inaccurate...
While ago I just got bogged down on a slick dirtroad until I slid into a ditch. The ditch was not very deep, I'd say the car was tilted (left side down) about 20 degrees, until I got pulled out.
Before I got stuck, my fuel gauge was showing a little above the one-half mark. Now it's showing it's on the three-quarters mark. I'm wondering if the car being tilted caused the fuel to go to one side, making it read higher (although now that I'm out and on level surface it still shows I have more fuel than it should). Or maybe all that mud could have clogged something...
This only happened about 30 minutes ago, so I have not had the chance to fill up and see what it reads.
Old 09-04-2011, 09:48 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Just got Camry stuck in ditch, now fuel level gauge is inaccurate...
Go and check it again, I bet the gauge is showing something different
Old 09-05-2011, 01:37 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Is it possible you could have dented the bottom of the gas tank? Could it have been pushed up from the bottom inward?
Mike
just got wrx stuck badmonkeynobanna Completed Projects / Gallery 9 07-23-2010 05:30 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 09:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 10:58 PM
fuel level gauge???? jeff983000gt F-Body Problem Diagnosis 3 05-26-2008 10:50 AM
help installing a fuel level gauge? teck Exterior | bodykits | Lighting 0 08-06-2002 11:01 PM
