Old 09-04-2011, 03:53 PM
bungea bungea is offline
car audio
im installing a sub and amp to my aftermarket stereo. I have everything hooked up and when i change the track on my cd player i hear a thump. On lpf on the amp i can hear the music with little distortion but on full or hpf i hear a thumping sound making the sub continuously. Im running a 200 watt mtx amp with a 200 what max mtx sub.
I don't want to use a ground loop, id rather find the source and fix it.
Car is a 2007 grand prix gt if that info is needed. power wire is ran on passenger side do to battery on that side, and remote and rca on the other. ground is by the bolts on trim on rear seats where the top of the seat latches and to bring down the seats for more cargo room
Old 09-04-2011, 05:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: car audio
LPF is short for low pass filter, HPF is short for high pass filter. What that switch is is for a crossover. When set to low pass it will only let the low frequency signals through. With the subwoofer you want it set on low pass.
It sounds to me like something is not hooked up properly or something is not making proper connection. I have the exact same amp and it works flawlessly.
Old 09-04-2011, 05:43 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: car audio
Had an old head unit that used to do this through the speakers.
Was something in the head unit that put out a signal during changes in track.
Sounds like the amp is picking it up and amplifying it through the sub.
Old 09-04-2011, 08:21 PM
Re: car audio
yes i do have an old aftermarket stereo, but buying a new head unit a jvc kd s27 i believe does the same thing. i'll have to check all my wiring again, hopefully not down pouring like it is today, but im sure all connections are tight.
Old 09-04-2011, 08:26 PM
Re: car audio
does the ground wire placement matter where i have it or would it be better by the seat belts? Also when i take the rca's out the noise stops, i put one in and other out and noise isn't there either, place the other in and the noise begins. I'm almost thinking its the rca's.
Old 09-04-2011, 08:39 PM
Moppie's Avatar
Master Connector
Re: car audio
Could be a bad connection inside the RCA?
The earth contact just needs to be metal to metal, and directly to the frame of the car to be sure that is a good connection.
Old 09-04-2011, 08:57 PM
Re: car audio
the connection I'm using right now is metal to metal. I don't know if your familiar with the 04 to 08 grand Prix;s but the rear seats fold down and there's a plastic trim but behind is a metal washer then my ground wire, then the metal of the chassis.
regarding the RCA's, i just bought a new pack of RCA's and will be trying that out tomorrow along with checking for tightness on the other wires from the deck.
Old 09-06-2011, 01:28 AM
Re: car audio
to let you guys know the issue was the rca cables. thanks for the posts.
Old 09-06-2011, 02:15 AM
Moppie's Avatar
Master Connector
Re: car audio
Awesome!
Glad you got it fixed, how does it sound now?
Old 09-06-2011, 11:18 PM
Re: car audio
alot better then what it did in my 97 grand prix. Only thing is that the bass rattles the right rear speaker a little. trying to figure how how i can re-mount them so it don't happen.
Jeremy Carlson 1994 Honda Civic - Car Audio and Elecrtonics ... - Car Audio Automotive News Automotive News Desk 0 08-07-2006 07:30 PM
It's audio, but not car audio... forgot what my other audio forums are... threedd97 Car Audio 20 12-22-2005 08:40 PM
Car Audio Novice Needs Major Help Purchasing An Audio System For A New Car MadMardigain Car Audio 5 08-03-2005 11:40 AM
Car Computer and Car Audio Equipment 4 Sale nightriderweb Group Buy Market 0 05-03-2004 10:41 AM
