Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-03-2011, 05:35 PM
GSOEC GSOEC is offline
'99 Maxima engine light
I've got a '99 Maxima with the engine light on. I took it to get it checked out and the technician said it was the mass air flow sensor that needed replacing. So I had it replaced but seems that wasn't the issue. Problems that I continue to have is that when I turn the engine off and then turn it back on less than 15 mins. I would have to press the gas pedal so the engine could start - if not it wouldn't start automatically. Another problem is when I'm driving and the engine light is on and then the battery and oil light comes on suddenly and the engine will slowly come to a halt and the steering mechanism will stop functioning. Hopefully its not in the middle of the HWY when it happens. Other than the problems the car drives fine. If there is any solution to this problem I'd greatly appreciate it!
Old 09-04-2011, 03:08 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: '99 Maxima engine light
- The only electronic change at startup, when gas pedal position changes, is TPS = throttle pos sensor. Various ways/tests to check it; see page6 in my linky. Your sensor (actually not sensor but a potentiometer) is smaller but functionally same. Possibly bad.
When engine is warm, no such 'pedal help' as TPS is totally ignored by computer. (if O2 sensor is ok, that is)
- For example, if ign sw is worn, engine power is lost = and engine dies: all panel lights do come on. Here only switch replacement helps. (there are other reasons why power is lost, like relays, badcontacts, broken wire...)
Mileage?
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 09-04-2011, 08:26 AM
The mileage is 182,000
Old 09-04-2011, 11:12 AM
That means up to 40.000 x startups (average). Most switches can take it, though if well lubed.
One can either just change the (60$ ?) switch, or make a bypass wire&switch that delivers power circumventing the ign sw - for test purposes.
This shutdown problem (which I guess is separate) can also be semi-burned inhibit relay: relays are color coded and can be test/swapped 'by anyone'. If u hit the right one, the problem will vanish and appear on some other device ctrl.
Also check the contact issue, most expensive issues to let 'TEPCO-class engineers' to troubleshoot. A cheap but laborous remedy against oxidated connectors.
Check Engine Light..... Stinff Equinox 2 11-01-2010 11:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 11:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 05:06 PM
