Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-03-2011, 11:47 AM
Jeeper1949 Jeeper1949 is offline
Question Brake Issue
Greetings,
I have a 2001 Grand Cherokee Laredo with power brakes. Quite often when I am stopped at a light I find that the brake pedal slowly goes down towards the floor. Since the lights are short it neve makes it to the floor. I have checked each wheel and found no fluid leaks.
Is this a problem with the master cylinder or the power brake assist? Or, could it be something else like needing the brakes bled.
Thanks in advance for your help!
Old 09-11-2011, 10:39 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Brake Issue
Sounds to me like your master cylinder is dying....if there are no leaks and the fluid level stays where it's supposed to be that would be my call. If the fluid level goes down over time then there's a leak.
I don't think it's a "need to bleed" issue, since you didn't say that your braking performance has been reduced. Air in the system will make your brakes much less effective.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
The Following User Says Thank You to fredjacksonsan For This Useful Post:
Jeeper1949 (09-12-2011)
Brake issues GodsGirl73 Caravan | Voyager 4 05-05-2010 05:45 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 11:14 PM
03 Malibu Brake Issue frame1520 Malibu 1 03-01-2009 10:25 AM
help, speratic brake issues and throttle-off-idle issues. 94tegRS Camry/Camry Hybrid/Vista 3 11-08-2006 03:56 AM
Diablo 6.0 Mods, and e-brake issue cewhitman Diablo 3 04-04-2002 08:51 PM
