Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 09-02-2011, 02:05 PM
stylesdude stylesdude is offline
G10 won't start I'm stumped
Okay, first its a 96 g10 1500 350 vortec.
mileage is around 167000
was driving engine died, coasted to stop and would not turn over. so i ended up changing the fuel pump, still no start.
got spark, fuel, engine turns, checked fuel relay(ok)
my mechanic ran a diagnostic scan, while the key is in off position he is getting map sensor reading airflow engine temp etc. as if it was actually running, when key turned on readings act as if the engine is off. someone told me that the battery could cause this if the charge was too low, essentially confusing the brain box. is this possible?
if so what's the next step if the battery is not the problem?
Old 09-02-2011, 04:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: G10 won't start I'm stumped
Has anyone load tested the battery on this vehicle? Low voltage will cause all kinds of problems.
The Following User Says Thank You to gmtech1 For This Useful Post:
stylesdude (09-03-2011)
Old 09-03-2011, 12:47 AM
that is going to be done tomorrow morning, thank you. i will post the result when it is done. thank you.
Old 09-05-2011, 03:39 AM
thanks for the help, new battery worked, but apparently someone else has been under the hood and rearranged the relays. so once i put those back in their places it works perfectly. thanks again.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 04:39 PM
'04 Neon died and won't start, everyone stumped, please help! icon_xof 2nd Gen 00-05 16 03-12-2011 11:14 PM
99 Regal LS stalled now won't start mfraumeni Regal 7 04-05-2010 01:38 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 10:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
Tags
1500 , chevrolet , chevy , g10 , sportvan
