Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 09-01-2011, 10:21 PM
GCAJH77 GCAJH77 is offline
Question Interior lighting - 2007 Honda Civic EX
I have a 2007 Honda Civic EX and was in a car accident a few weeks ago. I had a lot of work done to repair the front of the vehicle. I got the car back 2 days ago and have been inspecting it to make sure everything is as it should be. Once driving it at night... something seems different about the interior lighting somewhere around where the speedometer, mileage gage, steering wheel, radio, and/or air conditioning controls are... I just can't put my finger on what it is exactly and I don't know if it's just because I got used to a different lighting in the rental car that I drove for 3 weeks.
The main thing I am not sure about: BEFORE, after I cranked up the car, I don't remember the lighting of everything (that was already lit before turning on the the headlights) dimming down once turning on my headlights... I thought that it stayed the same brightness even after turning on my headlights... but now it gets significantly dimmer. Can someone with this model/year civic - who has one in good condition - please tell me what happens when you turn the headlights on? Or someone with a lot of knowledge of this specific model/year civic?
The other big thing: The area that controls the air conditioning lights up so that I can see it in the dark, but no part of my radio/auxiliary/cd unit control area lights up so that I can see where it is in the dark... all I can see in the dark is the blue screen that tells what I'm presently listening to. I can't remember... should I be able to see this area (with the volume/channel knobs, saved station buttons, forward/rewind buttons, aux/cd/radio buttons, etc.) lit up?
Old 09-04-2011, 10:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Interior lighting - 2007 Honda Civic EX
sounds like a fuse or wire is bad somewhere
Old 09-05-2011, 03:59 PM
Copytech99 Copytech99 is offline
When the lights are on try pressing the + button until you hear a beep and see if that is the brightness you had before.
There is 1 setting for when lights are off, and also 1 setting for when they are on.
The missing audio unit illumination may be another matter though.
Old 09-10-2011, 08:23 PM
Thanks this helped!
Old 09-10-2011, 08:24 PM
I don't think it's the fuse because it looks fine to me. So I'm thinking it the wiring. Thanks
Old 09-11-2011, 07:51 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i had that same issue, i didnt realize there were different settings for the dash brightness whether or not the lights were on.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-12-2011, 06:32 AM
For the audio illumination... it was quite common on early models for this section of the head unit to fail making all of the audion buttons dark at night.
I will look up the connector info and edit the post when I have it. You can measure voltage with the lights on and illumination brightness level on high. If the voltage is present you likely have a problem with the head unit.
Old 09-12-2011, 04:06 PM
At head unit connectors:
Connector A Pin 1 = RED = dash lights brightness controller (use negative meter lead)
Connector A Pin 10 = GRAY = Illumination + ( use positive meter lead )
Measure voltage with parking lights on and brightness set to max.
If you have voltage present under this test the problem will likely be in the head unit.
Old 09-05-2012, 10:52 AM
Ethenhunt06 Ethenhunt06 is offline
I am also much interested in interior car decoration. As i bought new Honda City want to make it cool look like me.If any one have more suggestion for me please make it share to me What make my car more comfortable and luxuries.
2003 Venture Interior Lights OnThePike Venture 16 12-03-2010 12:39 PM
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 05:06 PM
98 Olds electrical - interior lights turn off 63johnm Silhouette 0 07-12-2010 12:32 PM
2007 Honda Civic Type R: The Legend Returns - Moldova.org Automotive News Automotive News Desk 0 02-28-2006 11:10 PM
