Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-31-2011, 12:39 PM
caw333 caw333 is offline
CKP sensor help
Crankshaft position sensor. Codes p0339 and p0341 and p1336... Ok I checked the sensor voltage on the thing like the haynes book said and it told me I should be getting around 5.0 volts on the signal wire and I'm getting 1.8 to 2.4 at idle so i pulled the sftermarket autozone sensor out and it shows signs of light rubbing on the reluctor wheel. Does anyone know about these sensors. The truck idles rough with some backfires.
Old 09-01-2011, 06:26 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: CKP sensor help
Year make and model and engine?
On some years makes and models and engine there is a TSB on shiming sensor if it is rubbing on end.
Try shiming it up to where it does not rub.
MT
Old 09-01-2011, 08:30 AM
Re: CKP sensor help
98 tahoe LT 350.
Old 09-01-2011, 04:25 PM
MT-2500's Avatar
AF - Advisor
Re: CKP sensor help
98 tahoe LT 350.
Repair the rubbing problem.
Check wiring and plug in real close to.
Make sure it is the right OEM type sensor.
My repair manual doed not show tsb for that year make and modle and engine.
Biut.
Check with dealer on TSB and shims for it.
Some can be shimed or in real bad cases the timing cover has to be replaced.
Get it where it does not rub and then clear codes annd watch for any coming back.
Let us know how it goes.
MT
Old 09-01-2011, 06:47 PM
777stickman 777stickman is offline
Re: CKP sensor help
P0339=CKP (Crank) intermittent circuit. Follow MT's advice.
P0341=CMP (cam) sensor performance. Usually caused by electromagnetic interference. Check CMP wiring harness for proper routing.
P1336=CKP System Variation not Learned. Any time a CKP is replaced this procedure needs to be done. It requires a high end scan tool in the hands of a competent technician.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
90 olds crank sensor trouble MikeWolf Ninety Eight 11 07-12-2010 01:18 PM
97 camry V6 02 sensor help!! machinehead26 Camry/Camry Hybrid/Vista 3 10-25-2009 07:44 PM
CKP sensor??? qtmac_mien '96-'00 Civic 5 03-19-2006 09:16 PM
failed smog code 1345 CKP sensor chilton book renno Sierra 7 05-06-2005 08:06 AM
1996 Sierra CMP and CKP Sensor KevRho Sierra 7 12-21-2003 07:01 AM
