Old 08-30-2011, 11:26 AM
Firstymer Firstymer is offline
Ac=no cool air blowing
Greetings fellow ladies and gentlemen, my 00’ GP SE V6 3.1L 130,400+ KM is faced with yet another issue, AC cooling. I noticed for the past weeks with the extreme temperatures reaching 100 degree in Florida my AC hasn’t been blowing cool air though it is blowing pretty strong whether its on low speed or high. I recently purchase a 134a refrigerantcanister to see if that would solve the issue unfortunately the problem is still there. The gauge reads the refrigerant is full. I look forward to hearing all advices and suggestions to help solve this issue before I take it to a pricey mechanic shop. Thanks!
Old 08-30-2011, 11:30 AM
Tech II Tech II is offline
Re: Ac=no cool air blowing
Need to know EXACTLY what the high and low side pressures are....if there is a code in the car......If system pressure is ok, could have a pressure sensor problem.....
Old 08-30-2011, 12:49 PM
Yes, I believe the pressure from the low port is up to specs, however, I am not sure if the compressor is operating correctly.
Old 08-30-2011, 12:50 PM
Perhaps, I should take it to Autozone to get a code reading.
Old 09-03-2011, 11:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
If you want to waste your time. Do you have a check engine light on? Running a scan for odb-ii codes won't help fix your A/C issue. An A/C Pro would be better if you do not have the right diagnostic equipment or skills.
Timeslip 08/12/06
AF Community Guidelines
Old 09-06-2011, 03:35 PM
StevePT StevePT is offline
Does the compressor clutch engage when you turn on the AC? The Grand Prix uses a Delphi V5 AC compressor which is variable displacement and will rarely ever cycle the clutch, so if you turn the AC on, then go look at the compressor the clutch should be engaged and spinning with the compressor pulley.
2003 with Dual Air, NO cool air in the rear sbellesc Tahoe 2 04-17-2012 10:37 PM
AC starts but no cold air blow out when engine is off crispswish Engineering/ Technical 7 08-15-2009 06:36 PM
AC problem: no cool air dingzhijia Grand Prix 1 03-26-2008 09:09 AM
Cool Air Blows Out When I Idle oneroundko Cavalier Problem Diagnosis 3 01-25-2008 02:33 PM
ac button stays on but no cool air on 95 mngrivera Grand Prix 2 06-28-2005 12:03 AM
