Old 08-29-2011, 06:54 PM
1534dover 1534dover is offline
Additive for coolant leak
my 1995 Ford Taurus has a coolant leak. Is there a way to fix it without tearing the engine apart? About an eighth of a cup a day. Will GM Pills help this?
Old 08-29-2011, 07:02 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Additive for coolant leak
If you don't care about the car and have no long term plans for it, then there are plenty of different stop leak products that might, or might not work.
But, these products work by solidifying in the cooling system where is a leak to air, or a change in pressure.
They can often block critical passages in the engine and cause over heating problems in the future.
Can you see where the leak is?
Usually they are not that hard to fix, and long term it is always the better solution.
Old 08-29-2011, 10:59 PM
My mechanic says it is the gasket in a housing that would require three to four hours labor to remove if they didn't break any bolts in the process. Their experience is Ford bolts here often do break no matter how careful they are.
Old 08-31-2011, 01:38 PM
Willyum Willyum is offline
I wouldn't use anything unless it was a radiator leak in the metal. I once used just egg white that worked well for that.
For the engine you need to get serious.
Old 08-31-2011, 11:24 PM
I used one AC Delco Cooling System seal tab, apparently a fiber product. And one I think will do the job.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
Oil Additives for Slowing Leaks ihgrad Camry/Camry Hybrid/Vista 8 06-23-2008 08:45 PM
