Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 08-29-2011, 01:34 PM
westerner westerner is offline
P1071 Error Code
Hey guys,
I've searched for this and haven't come up with much other than the same error code for a bunch of other vehicles, and a bunch of different responses. My Tacoma is a 2000 PreRunner, 3.4 liter engine.
The exact code I get it is:
P1071
bank 1 system too lean
Anyone know what this could be?
Thanks in advance for any and all help! Sorry if this has already been posted and I missed it in the search.
Old 08-29-2011, 05:45 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: P1071 Error Code
It is likely that you misread it and it is P0171. That is a common code for that engine
System too Lean (Bank 1)
Possible Problems
When the air fuel ratio feedback is stable after engine warming up, the fuel trim is considerably in error on the LEAN side (2 trip detection logic)
Air intake hose loose
Fuel line pressure low (may be from running out of gas)
Injector blockage
HO2 sensor malfuction
MAF meter or MAP sensor malfunction
Engine coolant temperature sensor malfunction
Clean MAF meter with electronic circuit cleaner or replace<= most likely
Fix vacuum/intake leak downstream of MAF meter
Inspect fuel lines for cracks, leaks, or pinches
Replace fuel filter
Check fuel pressure at the fuel rail
Check output of HO2 sensor
Check injector performance
Check ECT sensor
Check PCV valve and hose fittings for tightness
Most likely problem is dirty or contaminated MAF sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
01 Town & Country error code explanation jehanny Caravan | Voyager 3 10-14-2009 12:34 AM
2002 QX4:Error Code P1320 Michael.Jones Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-20-2009 11:09 AM
error code 300 no other codes brokeneckdave Blazer 6 02-07-2005 05:20 PM
Stalling, Bad Error Codes, Strange Error Lights mrwjr2003 Regal 0 05-21-2004 09:34 AM
Engine error code Pancor Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 03-12-2001 10:31 PM
