Go Back   Automotive Forums Car Chat > Hot Deals
Hot Deals A place to find and discuss the best deals online.
Old 08-28-2011, 03:57 PM
blazee's Avatar
blazee blazee is offline
Problem?
Gerber 31-000710 Evo Knife and Clutch Mini Tool Combo $19 (MSRP $55)@ Amazon
http://www.amazon.com/dp/B004EEOW5C/
Technical Details
  • Evo knife has a titanium nitride coated blade and anodized aluminum handle
  • Evo knife also has dual thumbstuds and pocket clip
  • Clutch mini tool has spring loaded pliers, outboard components and stainless steel blade
  • Clutch mini tool can be clipped to your keychain or carried in your pocket
  • Clutch mini tool is lightweight anodized aluminum
Product Description
From the Manufacturer
Introducing a clip folder for knife people who prefer the look of a straight spine; the profile reveals a "seamless" design that begins at the back of the blade and continues along the length of the upper edge of the handle. Another aesthetic design touch is the series of seven slanting oval openings in the anodized aluminum handle. They serve to make these knives both organic and aggressive. Functionally, the oval openings further reduce the overall weight of these knives to near nothingness. The blades are constructed of 440 stainless steel that is coated with titanium nitride for added corrosion resistance. There's a thumb stud for easy one-handed opening. And, there's an integral finger guard for an extra measure of safety. Bottom line, you'd do well to own such a highly evolved knife. How many times do your find yourself in a situation where you least expected that you'd be needing some pliers, a knife, or a screwdriver? The Gerber Clutch has been designed as the perfect bring-along tool to get yourself out of clutch situations. Whether you're putting together a graduation present or removing a splinter from your finger, you'll be glad you brought along the Gerber Clutch.
Product Description
Gerber's best selling knife and mini tool are combined to form the Evo and Clutch Combo Set. This is a great value and offers great savings when compared to buying each individual item. Evo Knife: Titanium nitride coated blade, anodized aluminum handle, dual thumbstuds and a pocket clip. Clutch Mini Tool: Spring loaded pliers, outboard components, stainless steel blade, compact design and a lanyard hole.
  • Available with limited quantities.
