Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-28-2011, 02:46 PM
Robert Hanson Robert Hanson is offline
Problem with Instrument Panel Guages
My 1988 TBird Turbo Coupe has developed a problem upon starting up, the instrument gauges do not work, nor do the power brakes. When this problem first occurred, after running for several minutes, the gauges and power brakes would begin to work, now they are now working at all. I also noticed that when you shut the car off and then turn the key a little before startup, the guages will work until the car starts.Any opinion as to what the problem may be would be appreciated.
Old 09-02-2011, 05:17 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Problem with Instrument Panel Guages
Welcome to the forum Robert. If you can get the guages to work by moving the key then it sounds like the ignition switch is worn out. Do none of the guages work? The power brakes work by vacuum applied to the power brake booster. Check the hose going to the booster to see if you have a vacuum leak.
The Original 97Bird
The Following User Says Thank You to 97Bird For This Useful Post:
Robert Hanson (09-03-2011)
Speedometer Display - Instrument Panel mooneyka Xsara | Xsara Picasso 0 01-06-2010 06:52 AM
Dash Cluster-Instrument panel -Guages andreval Cavalier Problem Diagnosis 3 02-20-2008 02:40 AM
Stereo Installation - problem with instrument panel lights Longmark999 Rodeo | Passport | MU 11 10-06-2007 05:40 PM
Problem with Instrument Cluster Zreon Integra 0 06-18-2004 03:38 PM
Problem with instrument lamps fuse Dr. Dolittle Century 5 12-30-2003 08:57 AM
