Old 08-26-2011, 06:46 PM
1534dover 1534dover is offline
Oil pan leak
I just bought a used 1996 Lasabre. There is a small leak from oil pan. What will repair likely cost?
Old 08-26-2011, 10:22 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Oil pan leak
If you have a shop preform the work, the cost shouldl be close to $200.00 The gasket cost is only $28.79, if you choose to buy it @ RockAuto Parts Catalog FEL-PRO Part # OS30767R & have it installed. Paying only labor for 1-hr, you might save some $. BTW, anyone who claims the job is more than 1-hr, is pulling you leg.
The Following User Says Thank You to HotZ28 For This Useful Post:
1534dover (08-27-2011)
Old 08-27-2011, 03:07 PM
Jrs3800 Jrs3800 is offline
Re: Oil pan leak
100%agree... The oil pan gasket/windage tray is a simple replacement on this engine...
The Following User Says Thank You to Jrs3800 For This Useful Post:
Old 08-28-2011, 08:34 AM
Tech II Tech II is offline
Re: Oil pan leak
As I stated in another post, you have to "seal" that new plastic gasket due to "ripples" in the flange of the the oil pan....
Old 08-31-2011, 09:47 AM
Re: Oil pan leak
Never heard that one before... The Fel-Pro gasket is an updated version to hlep correct for those problems... But what has to have sealer added is the points where the rear cover and front cover meet the block, if those are not as clean as they can be and sealed the gasket will leak...
I don't seal the oil pan gasket, but I do agree that a bead all around will prevent leaks..
Old 08-31-2011, 08:06 PM
Re: Oil pan leak
There is a TSB for this.......first time I ran into this, just replaced the plastic gasket, and it still leaked.....because of the "ripple" in the pan flange, I ordered a new one....new one had the same ripple.....called TAC, and they said the TSB would come out soon about RTV'ing the new gasket, due to the ripple effect of the flange.....
Old 08-31-2011, 09:00 PM
HotZ28's Avatar
AF Moderator Elite
Re: Oil pan leak
Never use silicone anywhere on the "new improved" Fel-Pro Perma-Dry oil pan gasket! This particular gasket, which is much improved over OEM GM gasket, is probably not available to dealers, without outsourcing after-market parts, (which they usually refuse to do.) My shop has used this particular gasket many times, on (new & OEM oil pans) as a replacement, and have never had a return complaint for a leak. In fact, I replaced the oil pan & gasket on my own '96 PAU (some idiot bent it with a jack) last year using this same gasket, & it is still bone dry. GM needs to write a modified TSB recommending use of the "new design" Fel-Pro gasket”, but I doubt they ever will
PermaDry® Fel-Pro PermaDry oil pan gaskets, made of premium molded rubber, are a good choice when repairing or rebuilding engines that were originally equipped with molded-rubber gaskets.
The rubber material and design provide even clamping along the entire oil pan, while grommets and other design features prevent over tightening.
FEL-PRO Warranty Information
12 months
Trying to Diagnose Massive Oil Leak - 98 GT doublea70 Grand Prix 6 07-23-2011 12:56 PM
2000 GC 2WD - Remove oil pan without removing exhaust y-pipe? jrandallc Grand Cherokee | Grand Cherokee SRT8 0 06-05-2011 08:31 AM
Searching for a Ford Pinto oil pan Mr 14 Prozent Engineering/ Technical 0 05-25-2011 07:01 AM
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
95 Odyssey Oil Pan Leaks cdc1948 Odyssey 2 07-18-2004 11:15 AM
