Old 08-26-2011, 10:27 AM
Bear Bear is offline
Gremlin in the Headlights
'96 Caravan 3.3 liter and the headlights come on whenever they wish. Car sits at curb, I look outr and the headlights are on, no switches are on to put them on. I was thinking headlight switch but now am leaning toward BCM. Does anyone know if BCM will code using a basic OBD-II scanner?
Old 08-26-2011, 12:38 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Gremlin in the Headlights
You'll need a scanner capable of reading communication codes ("U prefix" instead of "P"). Slim chance but have you tried the reset trick? Pull the IOD fuse for 2-3 minutes. It's in the underhood fuse box. Some have had success disassembling the switch and cleaning it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-26-2011, 01:26 PM
Thanks for the response, nothing to lose so I'll give it a try.
Old 09-02-2011, 07:16 AM
Well, moved car to high ground as Irene approached, disconnected the negative battery cable, and after two days retrieved Christine, and all is well. Go figure.
Old 09-02-2011, 08:38 AM
b1lk1 b1lk1 is offline
You reset the BCM and this can and has fixed various glitches in these vans. It may not be permanent, but with any luck it is.
Old 09-02-2011, 08:40 PM
Thanks for the post. I tried the negative cable off for about 30 minutes when this issue first started but it did no good, I guess two days works better. We will see.
Old 09-06-2011, 06:12 PM
You are going to love this. With Irene approaching I moved the car to high ground, removed negative cable an d left her for two days, went back hooked up the cable and drove her home. One week later and all symptoms are gone. I guess iI reset the BCM but how many days should that take?
How the heck do you pull the headlight bulbs out?!! GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 13 05-11-2005 12:27 AM
How do you change the bulb in the Headlight SIU60827 TrailBlazer | Trailblazer EXT 1 10-10-2004 05:12 PM
will the Fog come off of the headlights...? hellah fresh Off-Topic 30 08-15-2004 12:48 PM
Removing the amber strip on the headlights CraniumDesigns Exterior | bodykits | Lighting 4 05-24-2002 01:36 AM
whats it the number for the headlights TerryJoe Exterior | bodykits | Lighting 4 03-07-2002 03:38 AM
