Old 08-26-2011, 10:06 AM
StephenMS StephenMS is offline
1991 Camaro issue
Hey guys, bit of an issue with my car.
Basically it dies when thrown into drive.
Idle is great, reverse is great, neutral is great, drive is crappy.
If I let it sit for an hour or so, it will stay in drive without stalling, not for long though.
My MAP sensor connector is messed up I already know that but could it be causing my issue?
Also, I put antifreeze into my engine coolant reserve about 2 weeks ago, yesterday I checked it and it was just about empty. Any reason for that? I haven't noticed any leaks either.
Old 08-26-2011, 04:47 PM
Re: 1991 Camaro issue
Issue resolved guys! It was a bad coil and connector.
Old 08-26-2011, 06:14 PM
Tech II Tech II is offline
Thanks for posting the fix......
Check the weep hole of your w/p....
Old 08-31-2011, 07:52 AM
j cAT j cAT is offline
you must pressure test the cooling system. many items/components can cause this leakage...
many in warm non freezing areas owners/mechanic repairers do not install suffiecent coolant with the distilled water. then when the metal corrodes the leaks begin. when the coolant gets dark in color this says the leaks are coming.................this is the metal in the coolant !
95 camaro LT1 runs good cold, when hot has issues dimocamaro95 F-Body Problem Diagnosis 6 11-12-2010 04:09 PM
98 Camaro electric and fuse issues Rkeefer23 F-Body Problem Diagnosis 2 12-20-2009 01:00 PM
86 camaro irocz posiman F-Body Problem Diagnosis 2 11-23-2009 08:50 PM
I am getting a 1991 Camaro! CivicGen4 Camaro Discussions 9 02-15-2003 11:03 PM
1982-1991 Camaro Pimpin Yoda Camaro Discussions 4 01-26-2003 02:13 AM
