Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 08-25-2011, 01:07 PM
mika3585 mika3585 is offline
need help car wont move
okay today i was driving my car on the highway and it was slowing down fast and i pulled over and now it wony move its like its stuck in neutral i have a 1995 geo prizm 5 spreed manual car what to do i don't what to do and is a vw passat 1999 or a audi a4 2002 is a good car and what is a stage clutch
Old 08-31-2011, 05:05 AM
PressKean PressKean is offline
Re: need help car wont move
Hello. In order for anyone to help you in this case, you'll need to provide more details. First things first, can you start your car? If you can't, check your starter or your battery. If your car can start just fine, then this is where you'll need to read my comments.
1. Check whether your RPM is rising whenever you step the accelerator. If it does,
2. Check if you're handbrake is the one that has problem. It's the same concept as any electronics. Your handbrake may be broken and even when you let it go, it might still be applying the brakes.
3. Check if your transmission is working properly. Sometimes, if a vehicle is old and doesn't get serviced properly, there would be problem shifting gears. Is your car manual or auto?
Does you car budge a little higher when you accelerate? If that's the case, your handbrakes might be the problem..
Hit the brakes with the best car mods for your hot rod.
Link removed
Old 08-31-2011, 07:01 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Since you mention that your car is a manual, you might have a clutch that is shot. If it's a manual clutch (not hydraulic) it may be adjustable, but if it's so far out of adjustment that your car won't move, chances are pretty good it needs something more than just an adjustment. Were there signs of clutch slippage leading up to this issue?
Another area to check would be for a broken CV joint or half shaft axle. With the front differential in the transaxle, if one of the joints or shafts breaks, the differential will keep the car from moving much, if any.
-Rod
Old 08-31-2011, 07:59 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
To answer the second half of his run-on question, I think that the VW or the Audi are huge steps up from the Metro. Reliability is average for both but the Audi would be more fun. Insurance for both would be much higher too, especially the Audi. Finally, the VW might not need it, but most Audis require premium gasoline. Make sure you can afford the higher fuel costs when making this big of a step.
I'm guessing you resolved the no-go problem...hope it worked out.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-01-2011, 04:50 PM
Hello. Is your problem already solved? I'm pretty sure we'll love to know if it has been solved.
Link removed
Old 03-27-2012, 07:21 PM
yes the car did get fix around halloween last year and now i lose the engine because if money problem and trying to fix it keep on being push back by my dad when i keep trying to get it fix do now i am getting a new car
Old 03-27-2012, 09:58 PM
ricebike ricebike is offline
heythankyoufortakingthetimetoupdatethisthreadwerea llyappreciateitverymuchandespeciallythatyoudidntgo intodetailonwhatthefixwasandhowyoukilledyourengine imguessingyoubrokethetimingorheadgasketright
Old 03-28-2012, 06:30 PM
no my dad keep pushing back my oil change. and the lifters needed replace so when i fanilly got a oil change there was oil stabilizer was put in and not taking out so with that it killed it
I need HELP car wont start in cold please help bmwjoe Tech Check 1 04-22-2008 10:51 PM
Chipped A6 2.7T, need help, car doesnt move Bronigs '96 - '04 2 07-18-2004 10:04 PM
Need Help!! car wont start 1990toyotaPickUp Pick-Up 3 07-17-2004 04:11 PM
really need help car wont run, new time belt tensioner 90talon Off-Topic 8 03-19-2004 09:46 AM
