Old 05-30-2003, 06:02 PM
oblaise's Avatar
oblaise oblaise is offline
Low Profile Tires
I was wondering if anybody knows where I can find some Low profile tires. I am asking because I bought some Fujimi Rims but the tires that come in the box are thick. Does anyone have a solution to my problem. Thanks.
Old 05-30-2003, 06:25 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
The tires in the revell integra kit are pretty low-pro.
Old 05-30-2003, 06:38 PM
oblaise's Avatar
yea but I need a several, I like the ones that came with my XS Tuning tire, awesome tires. Do you think I could sand them from the inside. I doubt it but I might give it a try.
Old 05-30-2003, 06:40 PM
integra818's Avatar
You can, but the sidewall will probably be like square-like. :o
Old 05-30-2003, 07:19 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
square-like???
i dont think there is a way you can just get low-pro tires w/o rims, i wish it ws like that though, that the thing with some Fujimi rims, tires are too damn thick
Rui
(modeling) = Click Here
Old 05-30-2003, 08:18 PM
christofurr's Avatar
christofurr christofurr is offline
If you do that, you'll end up with a tyre which is bigger than the rim, so it will fall off all the time. The only way to sand it down is from the outside, but you'll end up with no tread pattern.
Old 05-30-2003, 09:53 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Low pro slicks. I dont know if you like slicks are not but heres a way to make low pro slicks. Put the tires on a dremel bit and take a hobby knife, turn on the dremel and run the edge of the knife on the flat part of the tire.
-Mike
Old 05-30-2003, 10:30 PM
oblaise's Avatar
yea thats what sucks about it, damn fujimi and those thick tires.
Yea that has crossed my mind several times, but I want a tread pattern. I guess I will just have to settle for a thick wheel.
Old 05-31-2003, 10:31 AM
bigfrit's Avatar
bigfrit bigfrit is offline
A bit farfetched solutions you gus come up with!
Why don't you just take a tyre designed to go on a 15 inch or so rim and put this on a bigger rim, that way the plastic or rubber will stretch and the tyre will look flatter, making it a low-profile tyre!.
Olivier
