Old 08-23-2011, 05:17 PM
Northdan Northdan is offline
replace complete front strut assy
Hi guys!!
I realy need help!
I engaged my self in changing my front strut assy (bought used) cause my spring broke. Everything is loose, but i got a couple of questions!!
- How do i take off the strut from the nuckle?
- Do i have to compress the coil since i take out the hole assy and put a complet one back in?
- Can i get a complet step by step guide (with pictures would be great) please?
I got a windstar 2002
the strut is on the driver side
Old 08-23-2011, 08:14 PM
tempfixit tempfixit is offline
Re: replace complete front strut assy
Originally Posted by Northdan View Post
Hi guys!!
I realy need help!
Go to autozone.com and sign up for the repair guides, then look up your vehicle and it should have procedure.
hope this helps
Old 08-24-2011, 12:36 AM
catvents catvents is offline
Hi guys!!
I realy need help!
I did the job a year ago ( same reason, broken coil spring plus destroy a new Bridgestone tire) You do not have to compress the spring, disconnect the tie rod end from the knuckle, remove the pinch bolt that retain the strut to the knuckle. Do not remove immediatly the 3 nuts at the top of the strut ( just loose them). It could me necessary to soak with loose nut or PB Blaster the strut where it is attached to the knuckle. I have used a long pry bar to press down the lower arm which make the strut unstick from the knuckle. And after just remove the 3 upper nuts and remove the strut from the van. I have replaced both side the same way without problem. You can also take a look on the Autozone site like the other guy has recommanded.
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
The Following User Says Thank You to catvents For This Useful Post:
Moppie (08-24-2011)
Old 08-24-2011, 01:05 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
That's a pretty good explanation though.
Getting the strut off the upright/knuckle is hard on my strut type set ups. Once you have the pinch bolt loose, or even removed, it's just a matter of using enough force to separate everything.
Old 08-24-2011, 08:25 AM
phil-l phil-l is offline
I replaced the struts in my '00 Windstar. I consider it a reasonable job for a modestly experienced DIYer.
I used a spring compressor to help smooth removing the strut - but it can be done without the compressor.
Personally, I don't think installing a used strut is worth it: New struts don't cost that much. I know many on this site like the quick-strut units that already come with the spring installed. However, I bought plain struts and moved the original springs to the new strut - and didn't think it was that difficult. You would need a spring compressor to do this (the basic Harbor Freight compressor works fine; it's often on sale for $10). I'll also note that an impact wrench helps smooth this job.
Pics of my strut replacement project:
http://good-times.webshots.com/album/560513401mTnRfu
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 08-24-2011, 07:54 PM
Thank you for all your answers!
Got the job done, thanks!
Hard to pry the strut out of the knuckle like mentioned and did not need to compress the spring witch was my big concern but i still did put binders on it just as a precaution.
phil-l
Saw your pics before (nice!) but was not sure about the compression part!!
catvents
Fortunately, my spring did not bust my tire, don't know what happened!
Thanks
The Following User Says Thank You to Northdan For This Useful Post:
Moppie (04-12-2012)
Old 04-03-2012, 09:52 PM
harryvil harryvil is offline
phil-l
catvents
Thanks
After that, did you have an alignment
96 Cam LE new front struts-wheels pulling hard, both directions Maulana Camry/Camry Hybrid/Vista 17 08-05-2011 02:50 PM
Q about a part in strut assy - Avalon 98 98avaloner Avalon/Pronard 2 06-28-2008 03:36 PM
325ix Front Strut Replace hugger59 3 Series 0 12-27-2003 04:36 PM
Front Strut replacement problem jnissley Tires and Wheels 1 11-20-2003 09:35 AM
G20 front strut replacement bigjimslade Suspension 0 03-05-2002 03:00 PM
