Old 08-23-2011, 03:23 PM
Tiggetty Tiggetty is offline
Ripping out ignition cylinder?
I have a 99 olds intrigue, 3.5.
i likely will be junking this car in a 6 months or so but it has served me well for quite a while. My ignition cylinder is failing, sometimes it takes me several minutes to get the key to turn and it has left my wife stranded a couple times now.
Does anyone know if popping the cylinder so i can start it with a screwdriver is a viable option on this car? if not does anyone have a way to start the car by bypassing the key altogether? i'm not interested in it being pretty, its a work car and is completely wrecked anyway. I have access to pretty much any tool i can think of and access to a large capacity machine shop.
Any help would be nice!
Old 08-23-2011, 08:12 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Ripping out ignition cylinder?
Do you mean the key will not actually physically turn? Or do you mean youre having trouble with the Security system not letting the car start?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-24-2011, 03:54 PM
Tech II Tech II is offline
Maybe he is stealing it?
Old 08-24-2011, 05:07 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Then ripping the barrel out won't help if the car still has a security system....
I doubt he's stealing it, car thieves don't normally seek advice on car forums.
Old 08-24-2011, 07:11 PM
Moppie:
"Does anyone know if popping the cylinder so i can start it with a screwdriver is a viable option on this car? if not does anyone have a way to start the car by bypassing the key altogether?"
I know popping the cylinder won't start it...he wants a bypass method and then he pops it?
Old 08-24-2011, 07:15 PM
Moppie's Avatar
Master Connector
Moppie:
Doesn't mean he's going to steal it
Have you never owned car where the ignition barrel failed?
I used to have an old Triumph with a push button start. It was easier to wire it in than replace the ignition barrel.
Ignition switch problem or ignition cylinder problem? winsett Accord/TSX/Accord Hybrid 5 02-17-2010 11:52 AM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
ignition cylinder won't come out yakko Regal 3 10-12-2007 10:46 PM
Ripping out the A/C 93weed_eater Integra 1 06-29-2003 07:09 PM
