Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-22-2011, 08:32 PM
sampleyr sampleyr is offline
99 silhouette headlights
I have a 99 silo and the headlights come on when I turn the key on and don't go off until I turn off the ignition. Light switch works with the key off. Also interior lights only work by the switch on the upper console not when the doors are opened. Any help would be greatly appreciated. Thanks
Old 08-24-2011, 07:27 PM
Tech II Tech II is offline
Re: 99 silhouette headlights
Some of these vehicles have a switch that turns off the int lights, so the lights don't come on when the door is open......check owner's manual for location....sometimes located in overhead console....
Your headlights come on as soon as you turn key on? Are these DRL's(daytime running lights)? Apply e-brake, then turn key to on....if light's don't come on, it's DRL's....
If you have auto headlights, could have a bad light sensor, or the sensor is covered on the dash......
Easy to tell the difference......if auto lights, the brightness of the radio display would go dim in daylight....if the radio display stays bright, it's DRL's.....DRL's are usually half the brightness of high beams...
The Following User Says Thank You to Tech II For This Useful Post:
sampleyr (08-25-2011)
Old 08-25-2011, 06:56 PM
Thanks for the information; I'll check what you said and get back to you.
PO171 97 silhouette strange intermitent problem midwestinavan Silhouette 14 04-09-2010 12:00 PM
headlights davidrobert2 Intrepid 1 11-20-2009 02:02 PM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 06:05 AM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 06:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
Tags
1999 , headlights , interior , lights , silhouette
