Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 08-22-2011, 11:55 AM
gtnmuddy gtnmuddy is offline
1996 c20, chevy van air problems
I know someone has the easy answer because I'm out of ideas.
Trying to repair the air conditioner on a 96 C20 chevy van.
Here is what I know so far:
1. 20 A fuse good
2. freon pressure switch working ok (has continunity)
3. Diode on compressor clutch good.
symptoms:
1. Clutch on compressor not engaging
2. heater fan not operating
What happened before all this:
1. Air was working but low on freon (R134)
2. freon and leak sealer injected in system.
3. Unit worked for about 45 minutes
4. blew 20A fuse
5. replaced fuse, no blower/compressor operation
6. 20A fuse did not blow again
My thought is maybe a fuse link in the wiring. I dont have a schematic of this unit so troubleshooting is by guess.
Anyone got any ideas?
Larry
Old 08-30-2011, 05:18 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1996 c20, chevy van air problems
1. 20 A fuse good
symptoms:
4. blew 20A fuse
Larry
I do not show a G-20 in 96.
Fuse for selector switch should be 25 amp.
No blow and compressor engagement.
Check selector swith for power in to it and power and out to blower and compressor controls.
Leak sealer in ac SYSTEM IS A NO NO.
Only stops some leaks
It will kill your AC stuff.
MT
Old 11-16-2011, 10:12 AM
Ikeepitreelz Ikeepitreelz is offline
The Chevy Express was introduced in 1996 but doesn't show up in a lot of systems, I hear that it was in part because the old G-20 vans were produced until a few months into 1996, i don't know how true this is.
1996 Chevy Lumina ignition problem! RedAzureSkye Lumina 2 05-29-2011 08:48 AM
Chevy Van wont start chvyvan86 Express | G Van 1 11-12-2010 07:52 AM
97 2500 Van Gauges problem rramey0214 Ram Van 1 10-19-2010 08:35 AM
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 07:09 PM
Keyless Entry Installation Diagram for a 1996 Chevy Van? cj12345 General Discussion 0 08-03-2003 08:09 AM
