Old 08-21-2011, 02:30 PM
so2315 so2315 is offline
Parking Aid Module
Does anybody know where the module is located on a 2000 WIndstar? I had a bad sensor last year that I replaced and my problem went away. The light came back on and I took the cover off and went down the line replacing each sensor. That did not fix the problem, and I need to locate the actual module. Any ideas where it is at?
I checked each sensor with the van in reverse, and I can hear clicking in each one.
Old 08-22-2011, 09:24 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Parking Aid Module
It should be located behind the passenger side rear quarter trim panel. I think it's close to the jack assembly.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-28-2011, 12:12 PM
Just an update for anybody troubleshooting the park assist:
Last year I had the light come on my park assist button meaning there was a fault detected. I purchased a new sensor, took the rear bumper cover off, and replaced the sensor on the right and plugged it back in and checked to see if the light went off. If not I swapped them back and moved on to the next sensor until the light went away.
Having researched this, it appears that one can determine which sensor is bad by applying the parking brake, turning the key on (don't start!), and placing your ear by each sensor. You should hear a sound similar to a spark plug firing.
If you hear nothing at all, from any of the sensors, you park assist module is bad. If you hear sound from all of the sensors, your speaker is bad. The reasoning is this: If you hear noise from all the sensors, obviously they work. And you can deduce that the module which is the brains of the sensors is also working.
So, in my case the speaker was bad. I have a friend who has a repair shop and his Snap-On scanner was able to scan the rear sensors and tell me the code. The speaker is located on the passengers side, up in the headliner by the lift gate. It is in a large plastic case and held in place by one bolt.
I used a simple light bulb with 2 wires to test the circuit once the speaker was removed. The light on my dash went out, and the light bulb flashed instead of the beeping the speaker put out. I knew I had found my problem!
I then began my quest to find another speaker.I called the dealer for the speaker, and was quoted $35. Only problem is they are on national back order, with no date set. I went to a junkyard and bought one for $15. Plugged the new speaker in and all is well.
I hope my work can help anyone trying to fix the park assist. It has 3 components.
1.) Sensors
2.) Module
3.) Speaker
I found it hard to believe that my speaker went out and threw the system into a fault mode, but I found out the hard way after tearing the bumper off, pulling each sensor out and so on that you can trouble shoot it with your ears and a simple light bulb.
The Following User Says Thank You to so2315 For This Useful Post:
MARZBX157 (08-30-2011)
Park-Aid, Ultrasonic Rear Parking Assist, URPA Help! :-) bpopilek Silhouette 3 01-14-2011 08:34 AM
Park-Aid (Ultrasonic Rear Parking Assist) Help bpopilek Venture 7 10-28-2010 07:24 PM
