Old 08-21-2011, 11:34 AM
fordseacruise2 fordseacruise2 is offline
1997 Ford Escort wagon heater/air fan not working
Hello,
I just stepped into my1997 Escort Wagon and started it up. I reached over to turn on the air conditoning and the fan did not come on at all. I checked my fuses inside and outside(under the hood) and nothing seems blown.
I would appreciate any advise to solve my problem
Thanks
Ken
Old 08-22-2011, 07:48 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 1997 Ford Escort wagon heater/air fan not working
I had a problem like this. The electrical connection at the motor was burned. Turn the switch on then try wiggling the wire where it hooks to the fan motor.
Nevada Tumbleweed
Old 08-25-2011, 08:12 AM
zzyzzx2 zzyzzx2 is offline
If it's anything like my 1995LX, the fan blower also has it's own circuit breaker. Check it.
Old 06-27-2012, 02:06 PM
amnslkr amnslkr is offline
The blower motor is housed in the right footwell on the passenger side. Behind the housing there are two blue wires that plug into the blower motor resistor. Most likely this is what is causing your problem. Replace that and the end of the melted connector that you will most likely have. (you can get a new terminal at radio shack and crimp/solder it on).
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 09:09 PM
Help me with an electrical problem on Ford Super Wagon. doodlebug1 Engineering/ Technical 4 06-18-2009 06:45 PM
97 ford escort lx headlights stopped working christopher1169 Escort 4 02-14-2009 09:48 AM
heater/AC fan not working mdhbhouse Caravan | Voyager 3 03-15-2005 05:01 PM
1997 Ford Escort Wagon - Interference Engine? alsohuman Escort 7 09-29-2004 09:10 AM
