Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 08-20-2011, 11:05 AM
isaacp79 isaacp79 is offline
2006 Xterra SE fuel cap/gauge
I have an 06' Xterra SE and was hoping someone could help me out with a few questions...
I am experiencing a lot of gas pressure/buildup in the fuel tank; noticeable when removing the gas cap to refuel. I have to let this pressure escape the tank before I can pump gas. Is my cap defective?
Also, the fuel gauge shows less gas than I actually have in the tank. For example, I will fill up and the gauge shows a full tank... 50-75 miles later is rapidly drops to half way. Maybe the float in the tank is broken and sinks below the actual level of fuel-causing an incorrect reading? errrr...
And lastly (the biggest inconvenience of all) is the time it takes to fill up... usually takes 20 minutes to fill up the tank (11 gallons of gas) as I am unable to set the fuel stream on the pump handle... half a gallon or so into fueling, the lever clicks off like the tank is full; leaving me to stand and hold the lever while filling-very slowly-to avoid any back flow... My guess is the position and angle of the fuel tube might be causing an excessive back splash inside the fuel tube... I dunno
Any suggestions/help will be greatly appreciated... Thanks!
2006 Pacifica fuel gauge acting crazy saturnthegiant Pacifica 2 04-24-2011 12:56 AM
2001 xterra electrical/gauge problems greenman23 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-15-2011 10:42 AM
**survey** for DIY fuel sending unit bvlauralee Rodeo | Passport | MU 2 12-11-2009 04:27 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
