Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-30-2003, 04:05 PM
97 black gsx 97 black gsx is offline
Send a message via AIM to 97 black gsx
crank walk?
i have a 97 gsx with 124,000 miles in it i bought and it was suppost to have crank walk but i found out the the water pump pulley was on backwards and theyjust put a new water pump and timing beltc so that was why it was throwing belts but now that i have got the pulley fixed i'm trying to found out if it has crank walk or not i only paid 2000 for the car and its in great shape so i think the guy that was working on it was trying to screw the guy over any tips will help thanks guys
drive it like u stole it
boost it
Old 05-30-2003, 11:11 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Throwing belts isn't really a sign of crankwalk. A fast ticking sounds, clutch to goes to the floor when you turn and thust bearing play are what you need to look for.
Old 06-01-2003, 01:32 PM
zer0bot's Avatar
zer0bot zer0bot is offline
does the clutch petal go to the floor by itself in a turn or only when you depress it in a turn
"It's like playing rock, paper, scissors and sucker punch to the throat. The sucker punch always wins."
Old 06-01-2003, 05:19 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
when u depress it will stick to the floor or it stick to floor during hard left turn one of the 2 I forgot
either it sounds like this http://www.eclipsegsx.com/downloads/crankwalk.wav
-Agim
Old 06-01-2003, 10:52 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
Signs of the final stages of crankwalk:
Ticking noise coming from the crankpully area as the CAS plate chews up the sensor.
Or
Clutch sticks to the floor durring a hard left turn (Weight transfer sloshes the crank towards the clutch and there isnt enough room in the bellhousing fore the pressure plate to disengage)
If you want to check crank walk for sure, you have the check the crank end play. Pull your oil pan (follow the directions in the manual if you don't know how) and take a flat head screw driver. Put it in between the crank and one of the caps and try to wiggle it. If the crankshaft moves, you are outta luck, if it doesnt, you are good to go.
Peace.
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 06-01-2003, 11:20 PM
EclipsNgirl EclipsNgirl is offline
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
I've had crankwalk for 1 year 10 months now...still driving it, but getting ready to take it into the dealer for a new motor...It's still driveable, but yet one of the worse cases people in our club have seen...I installed a SS clutch line to remove the restrictor...shifts like a dream now...it's never felt so good...but of course, it could go any day now...
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
Old 06-04-2003, 10:00 PM
TaLoN ESi DOHC TaLoN ESi DOHC is offline
Send a message via AIM to TaLoN ESi DOHC
Originally posted by FourG63 97GST http://www.eclipsegsx.com/downloads/crankwalk.wav [/b]
ok that sent chills up my spine
felt like first rising waves of a acid frenzy
-JaSoN
Few people understand the psychology of dealing with a highway traffic cop. Your normal speeder will panic and immediately pull over to the side. This is wrong. It arouses contempt in the cop-heart. Make the ba$tard chase you. He will follow.
