Old 08-18-2011, 12:06 PM
trox trox is offline
'00 S10 2.2 hard 2 start when warm
I recently put a new (remanned) 2.2 in the S10 and it starts great on the first start of the day as a fuel injected motor should. Hit the key and BAM!, it fires in the first revolution of the engine. Anytime after the first start of the day, Whether 10 minutes or after finishing work 9 hours later, it takes from 5 to 8 seconds of cranking and when it does catch, it takes some pedal to clear it up and then all is good. I haven't taken pump pressures yet and I guess the pump could be the issue if it don't provide optimum pressure when warm at all, even after 9 hours though? I'm only getting 21 MPG and was hoping for better out of a 2.2. Do I check fuel pressure at the capped fitting in the engine compartment on the line feeding the fuel rail? Any other thoughts out there?
Old 08-18-2011, 01:29 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: '00 S10 2.2 hard 2 start when warm
Yes check fuel pressure at scrader valve.
Any codes or check engine liights?
When was last good AC delco tune up?
Does engine crank over good when hard to start?
MT
Old 08-18-2011, 02:15 PM
Thanks MT-2500, I do have a CEL, my fuel gauge flips out at times so I have a code for that and the after CAT O2 sensor. Can the O2 sensor be telling the computer something cuz it's still warm? I replaced the plugs and wires when I installed the new motor as well as the fuel filter. New battery cranks well anytime.
Old 08-18-2011, 02:32 PM
MT-2500's Avatar
AF - Advisor
Bad or shorted 02 Snensor can cause all kinds of problems.
What are the code no?
Also check fuel pressure?
MT
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
hard start when warm, then runs rough 1/2 mile richardgrogers Corvette 2 02-21-2004 04:59 PM
Hard starts when warm but sitting 1/2 hour jjk C/K 3 02-09-2004 06:51 PM
